jmpaoli
#1 Posted : Wednesday, November 26, 2014 5:02:59 AM(UTC)
jmpaoli
- Be able to have the different transitions in all directions. for example to appear as a bottom-up (currently upwards only slide for example). or from right to left (very useful for title)
- For Luma key an option to invert the black and white levels of the key file.
- When you resize, moves the image that serves as the source luma key, it does not change the image keyed it keeps the original size and position
- Add the ontime event to trigger at a specific tc an event or a url eg for example to control a lightshow
- Add to the api the picture settings for rgb, black and white level, saturation and alpha
... to be continued
richardgatarski
#2 Posted : Wednesday, November 26, 2014 8:50:10 AM(UTC)
richardgatarski
jmpaoli,
I like some of your ideas. But I think it is much better if you create separate topics for each idea, and give each topic a desriptive name. This will make it easier for us to give votes and comments.
