Hello. I am using vMix's stream delay feature to streaming on YouTube, but I am experiencing issues with audio sync and audio robotic sounds due to the FPS not being properly displayed when we checked in the vMix streaming statistics. Is there any way to resolve this issues?
For vis, I've attached a log text. Please have a look.
ffmpeg started on 2023-04-16 at 14:51:17 Report written to "C:\ProgramData\vMix\streaming\streaming3 20230416-145116.log" Command line: "C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -f mpegts -i - -vcodec copy -acodec copy -bsf:a aac_adtstoasc -rtmp_flashver "FMLE/3.0 (compatible; vMix/26.0.0.42)" -f flv rtmp://a.rtmp.youtube.com/live2 ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686 libavutil 55. 76.100 / 55. 76.100 libavcodec 57.106.101 / 57.106.101 libavformat 57. 82.101 / 57. 82.101 libavdevice 57. 8.101 / 57. 8.101 libavfilter 6.105.100 / 6.105.100 libswscale 4. 7.103 / 4. 7.103 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Input #0, mpegts, from 'pipe:': Duration: N/A, start: 1.432033, bitrate: N/A Program 1 Metadata: service_name : Service01 service_provider: FFmpeg Stream #0:0[0x100]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(progressive), 2560x1440, 59.94 fps, 59.94 tbr, 90k tbn, 119.88 tbc Stream #0:1[0x101]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 212 kb/s [tcp @ 05454fa0] TCP Buffer has been set to 32980992 bytes Output #0, flv, to 'rtmp://a.rtmp.youtube.com/live2/ Metadata: encoder : Lavf57.82.101 Stream #0:0: Video: h264 (Main) ([7][0][0][0] / 0x0007), yuv420p(progressive), 2560x1440, q=2-31, 59.94 fps, 59.94 tbr, 1k tbn, 90k tbc Stream #0:1: Audio: aac (LC) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, fltp, 212 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) frame= 247 fps=0.0 q=-1.0 size= 6851kB time=00:00:04.09 bitrate=13702.2kbits/s speed=8.18x frame= 278 fps=272 q=-1.0 size= 7457kB time=00:00:04.59 bitrate=13308.5kbits/s speed= 4.5x frame= 310 fps=198 q=-1.0 size= 8247kB time=00:00:05.12 bitrate=13185.5kbits/s speed=3.28x frame= 342 fps=165 q=-1.0 size= 9017kB time=00:00:05.65 bitrate=13056.0kbits/s speed=2.73x frame= 371 fps=144 q=-1.0 size= 10137kB time=00:00:06.14 bitrate=13520.8kbits/s speed=2.38x frame= 401 fps=129 q=-1.0 size= 10780kB time=00:00:06.64 bitrate=13295.9kbits/s speed=2.14x frame= 434 fps=120 q=-1.0 size= 11574kB time=00:00:07.19 bitrate=13181.1kbits/s speed=1.98x frame= 462 fps=111 q=-1.0 size= 12408kB time=00:00:07.66 bitrate=13269.3kbits/s speed=1.84x frame= 500 fps=107 q=-1.0 size= 13702kB time=00:00:08.29 bitrate=13533.9kbits/s speed=1.77x frame= 530 fps=101 q=-1.0 size= 14280kB time=00:00:08.79 bitrate=13302.0kbits/s speed=1.68x frame= 562 fps= 98 q=-1.0 size= 15092kB time=00:00:09.32 bitrate=13254.1kbits/s speed=1.62x frame= 594 fps= 94 q=-1.0 size= 15907kB time=00:00:09.86 bitrate=13213.5kbits/s speed=1.57x frame= 626 fps= 92 q=-1.0 size= 16974kB time=00:00:10.39 bitrate=13375.3kbits/s speed=1.53x frame= 658 fps= 89 q=-1.0 size= 17714kB time=00:00:10.93 bitrate=13276.5kbits/s speed=1.48x frame= 690 fps= 88 q=-1.0 size= 18512kB time=00:00:11.46 bitrate=13228.7kbits/s speed=1.46x frame= 717 fps= 86 q=-1.0 size= 19351kB time=00:00:11.91 bitrate=13305.4kbits/s speed=1.42x frame= 754 fps= 85 q=-1.0 size= 20426kB time=00:00:12.53 bitrate=13353.3kbits/s speed= 1.4x frame= 786 fps= 83 q=-1.0 size= 21202kB time=00:00:13.06 bitrate=13294.0kbits/s speed=1.38x frame= 812 fps= 81 q=-1.0 size= 21898kB time=00:00:13.49 bitrate=13289.3kbits/s speed=1.35x frame= 844 fps= 80 q=-1.0 size= 23207kB time=00:00:14.03 bitrate=13547.3kbits/s speed=1.34x frame= 878 fps= 80 q=-1.0 size= 23915kB time=00:00:14.60 bitrate=13418.4kbits/s speed=1.33x frame= 910 fps= 79 q=-1.0 size= 24715kB time=00:00:15.13 bitrate=13378.1kbits/s speed=1.31x frame= 942 fps= 78 q=-1.0 size= 25515kB time=00:00:15.66 bitrate=13340.4kbits/s speed=1.29x frame= 974 fps= 77 q=-1.0 size= 26573kB time=00:00:16.20 bitrate=13435.9kbits/s speed=1.28x frame= 1005 fps= 76 q=-1.0 size= 27299kB time=00:00:16.71 bitrate=13376.1kbits/s speed=1.27x frame= 1037 fps= 76 q=-1.0 size= 28239kB time=00:00:17.25 bitrate=13408.4kbits/s speed=1.26x frame= 1069 fps= 75 q=-1.0 size= 29134kB time=00:00:17.78 bitrate=13418.0kbits/s speed=1.25x frame= 1101 fps= 75 q=-1.0 size= 30228kB time=00:00:18.32 bitrate=13516.1kbits/s speed=1.24x frame= 1133 fps= 74 q=-1.0 size= 31010kB time=00:00:18.85 bitrate=13473.6kbits/s speed=1.23x frame= 1165 fps= 74 q=-1.0 size= 31824kB time=00:00:19.38 bitrate=13446.5kbits/s speed=1.22x frame= 1197 fps= 73 q=-1.0 size= 32642kB time=00:00:19.92 bitrate=13422.3kbits/s speed=1.22x frame= 1229 fps= 73 q=-1.0 size= 33626kB time=00:00:20.45 bitrate=13466.1kbits/s speed=1.21x frame= 1261 fps= 72 q=-1.0 size= 34356kB time=00:00:20.99 bitrate=13408.4kbits/s speed= 1.2x frame= 1294 fps= 72 q=-1.0 size= 35198kB time=00:00:21.54 bitrate=13386.2kbits/s speed= 1.2x frame= 1326 fps= 72 q=-1.0 size= 36281kB time=00:00:22.07 bitrate=13464.5kbits/s speed=1.19x frame= 1358 fps= 71 q=-1.0 size= 37094kB time=00:00:22.60 bitrate=13440.9kbits/s speed=1.19x frame= 1388 fps= 71 q=-1.0 size= 37759kB time=00:00:23.10 bitrate=13385.4kbits/s speed=1.18x frame= 1420 fps= 71 q=-1.0 size= 38544kB time=00:00:23.64 bitrate=13355.0kbits/s speed=1.18x frame= 1452 fps= 70 q=-1.0 size= 39550kB time=00:00:24.17 bitrate=13401.4kbits/s speed=1.17x frame= 1486 fps= 70 q=-1.0 size= 40314kB time=00:00:24.74 bitrate=13346.9kbits/s speed=1.17x frame= 1516 fps= 70 q=-1.0 size= 40975kB time=00:00:25.24 bitrate=13296.9kbits/s speed=1.16x frame= 1546 fps= 70 q=-1.0 size= 41704kB time=00:00:25.74 bitrate=13270.0kbits/s speed=1.16x frame= 1578 fps= 69 q=-1.0 size= 42768kB time=00:00:26.27 bitrate=13332.2kbits/s speed=1.16x frame= 1610 fps= 69 q=-1.0 size= 43510kB time=00:00:26.81 bitrate=13293.9kbits/s speed=1.15x frame= 1642 fps= 69 q=-1.0 size= 44291kB time=00:00:27.34 bitrate=13268.2kbits/s speed=1.15x frame= 1674 fps= 69 q=-1.0 size= 45008kB time=00:00:27.88 bitrate=13224.6kbits/s speed=1.15x frame= 1706 fps= 69 q=-1.0 size= 46060kB time=00:00:28.41 bitrate=13279.5kbits/s speed=1.15x frame= 1738 fps= 69 q=-1.0 size= 46818kB time=00:00:28.94 bitrate=13249.1kbits/s speed=1.14x frame= 1767 fps= 68 q=-1.0 size= 47721kB time=00:00:29.43 bitrate=13282.5kbits/s speed=1.14x frame= 1799 fps= 68 q=-1.0 size= 48525kB time=00:00:29.96 bitrate=13265.5kbits/s speed=1.14x frame= 1829 fps= 68 q=-1.0 size= 49483kB time=00:00:30.46 bitrate=13305.4kbits/s speed=1.13x frame= 1862 fps= 68 q=-1.0 size= 50274kB time=00:00:31.01 bitrate=13278.1kbits/s speed=1.13x frame= 1894 fps= 68 q=-1.0 size= 51072kB time=00:00:31.55 bitrate=13260.8kbits/s speed=1.13x frame= 1926 fps= 67 q=-1.0 size= 52259kB time=00:00:32.08 bitrate=13343.3kbits/s speed=1.12x frame= 1958 fps= 67 q=-1.0 size= 52987kB time=00:00:32.61 bitrate=13307.6kbits/s speed=1.12x frame= 1990 fps= 67 q=-1.0 size= 53849kB time=00:00:33.15 bitrate=13306.3kbits/s speed=1.12x frame= 2022 fps= 67 q=-1.0 size= 54818kB time=00:00:33.68 bitrate=13330.9kbits/s speed=1.12x frame= 2054 fps= 67 q=-1.0 size= 55975kB time=00:00:34.22 bitrate=13400.1kbits/s speed=1.12x frame= 2085 fps= 67 q=-1.0 size= 56736kB time=00:00:34.73 bitrate=13380.1kbits/s speed=1.11x frame= 2118 fps= 67 q=-1.0 size= 57582kB time=00:00:35.28 bitrate=13367.4kbits/s speed=1.11x frame= 2154 fps= 67 q=-1.0 size= 58678kB time=00:00:35.88 bitrate=13394.1kbits/s speed=1.11x frame= 2186 fps= 67 q=-1.0 size= 59649kB time=00:00:36.42 bitrate=13416.2kbits/s speed=1.11x frame= 2218 fps= 66 q=-1.0 size= 60410kB time=00:00:36.95 bitrate=13391.0kbits/s speed=1.11x frame= 2246 fps= 66 q=-1.0 size= 61050kB time=00:00:37.42 bitrate=13364.0kbits/s speed= 1.1x frame= 2280 fps= 66 q=-1.0 size= 61905kB time=00:00:37.99 bitrate=13348.8kbits/s speed= 1.1x frame= 2310 fps= 66 q=-1.0 size= 62808kB time=00:00:38.49 bitrate=13367.5kbits/s speed= 1.1x frame= 2342 fps= 66 q=-1.0 size= 63606kB time=00:00:39.02 bitrate=13352.0kbits/s speed= 1.1x frame= 2374 fps= 66 q=-1.0 size= 64432kB time=00:00:39.55 bitrate=13343.0kbits/s speed= 1.1x frame= 2406 fps= 66 q=-1.0 size= 65484kB time=00:00:40.09 bitrate=13380.4kbits/s speed= 1.1x frame= 2438 fps= 66 q=-1.0 size= 66219kB time=00:00:40.62 bitrate=13352.7kbits/s speed= 1.1x frame= 2470 fps= 66 q=-1.0 size= 67034kB time=00:00:41.16 bitrate=13341.6kbits/s speed=1.09x frame= 2509 fps= 66 q=-1.0 size= 68148kB time=00:00:41.81 bitrate=13352.3kbits/s speed=1.09x frame= 2534 fps= 65 q=-1.0 size= 69134kB time=00:00:42.22 bitrate=13411.6kbits/s speed=1.09x frame= 2567 fps= 65 q=-1.0 size= 70043kB time=00:00:42.77 bitrate=13413.3kbits/s speed=1.09x frame= 2599 fps= 65 q=-1.0 size= 70752kB time=00:00:43.31 bitrate=13382.0kbits/s speed=1.09x frame= 2631 fps= 65 q=-1.0 size= 71560kB time=00:00:43.84 bitrate=13369.9kbits/s speed=1.09x frame= 2663 fps= 65 q=-1.0 size= 72648kB time=00:00:44.38 bitrate=13410.0kbits/s speed=1.09x frame= 2694 fps= 65 q=-1.0 size= 73390kB time=00:00:44.89 bitrate=13390.9kbits/s speed=1.09x frame= 2726 fps= 65 q=-1.0 size= 74170kB time=00:00:45.43 bitrate=13374.2kbits/s speed=1.08x frame= 2752 fps= 65 q=-1.0 size= 74854kB time=00:00:45.86 bitrate=13369.8kbits/s speed=1.08x frame= 2790 fps= 65 q=-1.0 size= 75948kB time=00:00:46.49 bitrate=13380.3kbits/s speed=1.08x frame= 2825 fps= 65 q=-1.0 size= 76924kB time=00:00:47.08 bitrate=13384.0kbits/s speed=1.08x frame= 2854 fps= 65 q=-1.0 size= 77464kB time=00:00:47.56 bitrate=13341.1kbits/s speed=1.08x frame= 2886 fps= 65 q=-1.0 size= 78441kB time=00:00:48.10 bitrate=13359.4kbits/s speed=1.08x frame= 2917 fps= 65 q=-1.0 size= 79276kB time=00:00:48.61 bitrate=13358.1kbits/s speed=1.08x frame= 2949 fps= 65 q=-1.0 size= 80057kB time=00:00:49.15 bitrate=13343.1kbits/s speed=1.08x frame= 2976 fps= 65 q=-1.0 size= 80818kB time=00:00:49.60 bitrate=13347.4kbits/s speed=1.08x frame= 3010 fps= 65 q=-1.0 size= 81858kB time=00:00:50.16 bitrate=13366.4kbits/s speed=1.08x frame= 3043 fps= 65 q=-1.0 size= 82753kB time=00:00:50.72 bitrate=13365.7kbits/s speed=1.08x frame= 3070 fps= 64 q=-1.0 size= 83391kB time=00:00:51.17 bitrate=13350.4kbits/s speed=1.07x frame= 3104 fps= 64 q=-1.0 size= 84117kB time=00:00:51.73 bitrate=13319.0kbits/s speed=1.07x frame= 3134 fps= 64 q=-1.0 size= 84959kB time=00:00:52.23 bitrate=13323.3kbits/s speed=1.07x frame= 3168 fps= 64 q=-1.0 size= 85612kB time=00:00:52.80 bitrate=13281.6kbits/s speed=1.07x frame= 3200 fps= 64 q=-1.0 size= 86375kB time=00:00:53.33 bitrate=13265.7kbits/s speed=1.07x frame= 3237 fps= 64 q=-1.0 size= 87265kB time=00:00:53.95 bitrate=13249.2kbits/s speed=1.07x frame= 3266 fps= 64 q=-1.0 size= 88380kB time=00:00:54.44 bitrate=13299.2kbits/s speed=1.07x frame= 3296 fps= 64 q=-1.0 size= 89204kB time=00:00:54.94 bitrate=13301.1kbits/s speed=1.07x frame= 3328 fps= 64 q=-1.0 size= 90152kB time=00:00:55.47 bitrate=13312.9kbits/s speed=1.07x frame= 3364 fps= 64 q=-1.0 size= 91232kB time=00:00:56.07 bitrate=13328.1kbits/s speed=1.07x [flv @ 0223a700] Failed to update header with correct duration. [flv @ 0223a700] Failed to update header with correct filesize. frame= 3388 fps= 64 q=-1.0 Lsize= 92372kB time=00:00:56.47 bitrate=13399.0kbits/s speed=1.07x video:90934kB audio:1327kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.119844%
