Is there a preferred/optimal method to ingest live DASH video that will keep the video active? It's possible to take it in with the VLC functionality, but at least with the source I'm using, the signal is not delivered after a short period of time.
Hello. The signal what protocol is? And when not in vlc delivered, how you make it again to work?
Originally Posted by: nikosman88  Hello. The signal what protocol is? And when not in vlc delivered, how you make it again to work? I don't know more specifically than MPEG DASH out of Azure. vMix is so far the first software I'm using to play it back. Optimistically the "options" field would allow something to be entered whatever version of DASH (since it does play), but I haven't found anything.
