broadcast safe vs full video levels
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
Hi all, I want to record a full video level mix. Is this possible?
Now when i compare the video levels from my camera (recorded on card) with the video recorded in vMix the levels are clipped to 100% (legal levels).
But I want to edit the file / mix later so I would like to preserve the full video level.
Anybody know where I can set this or how to do that (change recording settings to prores or something).
Or might the clipping happen in the capture card (using BM mini recorder in this case, where there is no such option).
greetings Stefan
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
I would check the capture card first. Check in BMD native app. Then in vMix you can correct the input to your liking via color adjust or color correction.
