Event-Tech
#1 Posted : Friday, November 21, 2014 6:00:48 PM(UTC)
Event-Tech
Hey Guys,
Built a reasonable edit machine and put my BMD Decklink Studio card in, hoping there wouldn't be any compatibility issues.
Wow, it worked.
Video in via HD-SDI port.
We carried on, trying to get a SD output working to drive the large LED screen my client wants to use, and we got that working too.
HD-SDI in check, HD-SDI out check, SD out check and then my team did something, which we are un-sure of.
Now we get a message
AddNewInput
Capture Device Is Not Supported, Device Reported the following: Capture
We tried re installing the drivers etc but as yet no luck.
We had excellent video in for quite a while.
tdurhamjr
#2 Posted : Tuesday, November 25, 2014 12:24:48 AM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
Post a screen shot.
thanks 1 user thanked tdurhamjr for this useful post.
Event-Tech on 11/25/2014(UTC)
#3 Posted : Tuesday, November 25, 2014 1:58:51 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
Note that the Studio card cannot be used for input and output at the same time.
So if you have external output running in vMix using the card, then you will receive an error when adding it as an input.
Event-Tech
#4 Posted : Tuesday, November 25, 2014 6:14:48 AM(UTC)
Event-Tech
Thanks Martin, assuming that is you.
Ever since I saw you on StudioTech, I had wanted to try this. Finally built a machine to try. Thanks again.
