schnookiecakes
#1 Posted : Wednesday, March 22, 2023 1:40:37 AM(UTC)
schnookiecakes
Philippines
I am having a problem with my vMix. When running a web source, my CPU goes 100% while my GPU runs only at 25%. I already tweaked and tried a lot of settings but the problem still persists.
I run the same setup with OBS and CPU usage is only around 20-25% with GPU at 11%.
When using vMix
when using vMix
When using OBS
when using OBS
Here are my PC specification:
- Intel i9-10900K
- 32GB DDR4 3200MHz
- RTX 3080 Ti
- Intel UHD 630 (using for the Fourth Monitor)
Thank you!
schnookiecakes
#2 Posted : Wednesday, March 22, 2023 3:05:13 AM(UTC)
schnookiecakes
Philippines
When External mode is enabled using BMD DeckLink 4K
External Mode Enabled
