rjwerth
#1 Posted : Friday, March 10, 2023 1:54:24 AM(UTC)
rjwerth
Can we please have the ability to create separate windows for all UI elements so we can do our own screen layouts in any resolution monitor we want? Full screen views have to be in the project resolution and I'd like the ability to see larger input previews on a big 4K screen even if I'm broadcasting at 1080p. The only way to do that now is if the main UI is on a 4K screen and of course, you have to show nearly everything. The audio panel has the ability to be on its own, but nothing else. Really, the next release should focus solely on updating the UI.
Thanks.
mavik
#2 Posted : Saturday, March 11, 2023 1:39:44 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
You can change the input size in Settings/Display/input Size
Production Department
#3 Posted : Sunday, March 26, 2023 7:13:07 AM(UTC)
+++1 In terms of function and operation Vmix is extremely solid. The next release should focus solely on updating the UI for better usuability.
