jsandytn
#1 Posted : Saturday, November 15, 2014 3:18:53 PM(UTC)
jsandytn
Hi Martin,
I've been working with clocks and counters in titles. Very impressive. I realize how, through triggers, I can start a countdown counter without opening the title editor. What a great capability!
I've also found, through examining the sample 'TimeClock' title as well as a post from 25 April 2012, that there are codes that can be added in text fields to provide sdditional clock and counter functions. The default code in the TimeClock example of [0:hh:mm:ss tt} does a great job of showing the current time. The code of {0:6:00PM|hh:ss:ss} does an equally awesome job at counting down to a start time that is in the next twelve hours (in this instance, 6:00 pm if it is in the next 12 hours).
Do you have a list of any other codes and what they can do. I have the codes for a clock and countdown to a specific time (above)? Are there more (like - count up to a set time)?
vMix is a very robust product, so I wanted to use what may be a supported but unpublished capability.
Jeff
