mflorian
#1 Posted : Wednesday, February 22, 2023 10:09:47 AM(UTC)
mflorian
We're working at another school attempting to get our vMix output as an NDI stream to their Daktronics video board. While we were working on the BirdDog 4K Flex and attempting to get that to communicate with the vMix, we noticed that the four NDI outputs from the vMix SEEMED to be showing up as potential inputs on the ShowControl for the Daktronics.
Is this possible to connect our NDI output as a live video feed this way? Or is this meant for something else like a ScoreBot feed or another input?
mavik
#2 Posted : Wednesday, February 22, 2023 4:34:16 PM(UTC)
mavik
I use the NDI outputs this way.
mflorian
#3 Posted : Wednesday, February 22, 2023 11:08:48 PM(UTC)
mflorian
Awesome! I failed to mention on the OP that when I attempt to use them, I get no feed from them at all - is there a procedure for getting the NDI feed to talk to Daktronics?
mavik
#4 Posted : Wednesday, February 22, 2023 11:21:33 PM(UTC)
mavik
try with studio monitor if the feed is actually working. If, it's more down to the dactronic side. You can also try live lan option if that is supported.
https://www.vmix.com/help25/index.htm?LiveLan.html
