ewdiller
#1 Posted : Thursday, February 16, 2023 11:15:30 PM(UTC)
ewdiller
Was trying to stream from a local high school and have done so plenty of times in the past ... and as currently as maybe a month ago.
Last night i got a handshake error with youtube
ffmpeg started on 2023-02-15 at 18:47:14
Report written to "C:\ProgramData\vMix\streaming\streaming1 20230215-184714.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 2500k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 2500k -maxrate:v 2750k -codec:a libfaac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/25.0.0.34)" -f flv rtmp://a.rtmp.youtube.com/live2/akvx-****-****-****-16sm
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 188.485000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 02f7e120] TCP Buffer has been set to 6571008 bytes
[rtmp @ 058d4640] Cannot read RTMP handshake response
rtmp://a.rtmp.youtube.com/live2/akvx-****-****-****-16sm: Unknown error
is there a way to pevent this from possibly happening again ...
is this a scholl network issue ...
Thank you for any help
#2 Posted : Thursday, February 16, 2023 11:27:29 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
I would suggest reaching out to vMix support:
https://www.vmix.com/contact-us.aspx
Possibly caused by 3rd party antivirus/security software blocking the connection on the computer.
Also note I have censored the stream key in your logs, as that can be used by anyone to stream to your channel, so best to keep that private.
ewdiller
#3 Posted : Thursday, February 16, 2023 11:29:21 PM(UTC)
ewdiller
Will do ... thank you
renpro
#4 Posted : Sunday, February 19, 2023 12:11:28 AM(UTC)
renpro
Command line:
I too began seeing YouTube connection errors as of February 12, 2023. Maybe this fix could help with your problem:
[b]FIX FOR YOUTUBE EMBEDING ERROR “ Youtube.com refused to connect”
Problem: As of February 12, 2023 I begin getting an error when attempting to setup my webpage for Youtube.com “LIVE” event links. I was getting the error Youtube.com refused to connect”. In the past these were the steps I used successfully until February 12, 2023:
1. After creating my content scheduling a stream with Youtube Studio, I would go to my channel
2. Select Customize Channel
3. In search bar I would put the year “2023” to ensure ALL content would list.
4. My latest content would be listed at the top of list and I would select the pen for details.
5. In the details page I would use the ICON to copy video link
6. I would paste in my webpage html or content interface.
7. When checking link As of February 12, 2023 I would get “Youtube.com refused to connect” error.
THE FIX:
A. Steps 1-4 still work.
B. On step “5” click on the link and a new window opens incognito, COPY THE URL
C. Paste in your webpage development tool and Wa-La you are back in business.
David in Kansas City
thanks 1 user thanked renpro for this useful post.
Matou on 5/12/2024(UTC)
Similar Topics
Handshake error RTMP at some locations YOUTUBE (General Discussion)
by PrepSpin 5/5/2017 4:23:19 PM(UTC)
