Sometimes I try multiple clicks to shutdown the program. I click the x to close, nothing. I right click the taskbar label and choose "close window", vMix then pops up and window to 'close' the program, I click 'close' and still nothing. Repeat and repeat and still nothing. I have to finally go into Task Manager to force close the program.
What is causing this super inconvenient issue?
@ stanleymic
Could possibly be a vMix Input and/or external peripheral device that is not shutting down properly causing vMix to hang while it waits for that to happen. Some TASCAM and RODE devices have been known to do that.
Having the same issue Since V26. Starts to shutdown on close (couple of windows inside Vmix flicker and the the program hangs.) This always happens. Even with no inputs.
Only way to close is to right click the icon on the task bar and click close.
Really Frustrating. Is there an error log anywhere?
