BigApple
#1 Posted : Tuesday, February 14, 2023 10:09:27 AM(UTC)
BigApple
So i zoom in on a video (e.g 5x max zoom in Position section). Now i can clearly see the zoomed video. Now here is my problem . Now i want the zoomed in video and make it smaller almost like a pip ... but now when i do that and try to make the video smaller it basically just unzoomes... how can i make the zoomed video smaller without unzooming ? Thank you for any suggestion to figure this out.
#2 Posted : Tuesday, February 14, 2023 9:02:59 PM(UTC)
@ BigApple
If I understand you correctly, I might suggest using the "Mix" Input for your PiP if you have vMix 4K or above:
BigApple
#3 Posted : Wednesday, February 15, 2023 12:30:25 AM(UTC)
BigApple
Yes i do have that version and yes you are right that does the trick... Much appreciated. Thank you for your thoughts on this.
