ELCHAPIN
#1 Posted : Friday, January 27, 2012 1:08:24 AM(UTC)
ELCHAPIN
Many over charges, but Martin errors
Vmix2012 and is the best on the market.
but if you want more, add solvent PIPI
PIP with frames, for more elegance
and presentation.
not only the PIP box, Square.
a circle or oval PIP would be good
Thank you for your good work
=================================== DE GOOGLE =======
Muchos sobre cargos , mas errores Martin
ya Vmix2012 es el mejor , del mercado .
pero si quieres mas , agrega PIPI con disolvencia
PIP con marcos , para mas elegancia
y presentacion .
no solo el cuadro del PIP , Cuadrado .
un circulo u ovalado seria bueno en PIP
Gracias por tu buen trabajo
