YAMM
#1 Posted : Friday, February 10, 2023 8:18:35 AM(UTC)
YAMM
Myanmar (Burma)
Hi All,
I need help for my new Vmix PC as i'm from asia and limited budget.
currently using Asus F501H laptop with 4800H CPU, 16gb Ram, gtx 1650 4gb + Atem mini Pro ISO.
Mostly Streaming to facebook live sales.
Why i want to change?
- to achieve better video quality (*from atem video black are crush and highlight are blown)
- to use like supersource switching camera, cropping, multiview etc
What i will use
- 4K 30fps camera x 3 (EOS R > HDMI out)
- Intro video
- Graphic logo, tickers
- Virtual inputs for cropping 4K video
- 1 x Fullscreen output
- 1 x FHD 30fps , 10/12 mbps streaming with High
So i have limited budget here's what i planning to do as below
-i5 13600k (vmix 4k reference system use i9 10900k which is about lower benchmark than new 13thgen i5)
-Z-690 (Asus ProArt Z690-CREATOR WIFI or MPG Z690 FORCE WIFI)* 2 x PCIe 5.0/4.0/3.0 x16 slot(s) (supports x16 or x8/x8 mode(s))
-ram 32gb
-rtx 3070 or 3060ti
-Decklink Quad HDMI Recorder or (should i use cheaper Elgato camlink pro?)
Kindly suggest me or if you use with new 13th gen i5 or i7 let me know above setup will work.
Thanks.
#2 Posted : Saturday, February 11, 2023 12:04:25 AM(UTC)
@ YAMM
These are the vMix minimum system recommendations for a 4K workflow:
https://www.vmix.com/pro...ce-systems.aspx#obsidian
