Hi, Is there a way to force extended display to be enabled on a Desktop even when there is no monitor/cable hooked up on the secondary display port of the PC? I simply want to be able to capture the extended display of the other PC. I do not want to output it on a real monitor. Also the secondary display port is DVI which I do not have right now. Tried searching the net but it is infested with "how to extend desktop" topics. I only found one really relevant discussion but it ended prematurely without any details as to what needs to be done http://www.avsforum.com/...nded-desktop-win-xp.htmlIt is a registry hack for windows XP. Anyone know similar technique for min 7? I search my Win7 Registry with DriverDefaultAlgoSettings entry but did not find any. Thanks
