aci85
#1 Posted : Saturday, January 14, 2023 7:04:28 PM(UTC)
aci85
Italy
Good morning everyone, I need help. I have a 2 camera ptz 30x. I use them with a generic ptz controller. Everything works fine, but there is a problem. When I have the zoom pushed, almost to the maximum, the pan and tilt zoom movements are abrupt, fast, I want them slow, natural, but it doesn't work. I set the pan and tilt zoom speed to minimum, on the cameras and on the controller. Pan and Tilt works better, but zoom is always too fast. I changed controllers and didn't fix it. Can anyone point me to some controller that does what I want? This link says Skaarhoj models do what I ask but are out of budget. I can spend 1600 euros max. I hope for your help. Thank you
M.T.
#2 Posted : Tuesday, January 17, 2023 11:55:40 AM(UTC)
M.T.
What make and model of PTZ cameras do you have? Are they Panasonic, or Sony, or Canon? Many budget PTZ cameras from companies other than these do not have the ability to zoom slowly. For example, most PTZOptics cameras cannot pan or tilt slowly when they are zoomed in all the way, and they cannot zoom slowly enough to be used in a typical production. Your problem might be an issue with the cameras themselves, not the controller.
Guest (4)
