	GT
	Title Wrong behavior with Pageing in case DataChange Animation is applied
                  Test_Pages.gtzip  (7kb) downloaded 19 time(s).  Test_Pages.gtzip  (7kb) downloaded 19 time(s).  Test_Pages.gtzip  (7kb) downloaded 19 time(s).Hello all. Could you tell me is it a bug or feature?   The strange behaviour of .gtzip title was found in case if there is at least 1 Page and DataChange animation is used. Simple example (gtzip attached):      Main page of title : One-line scoreboard with 2 rectangles and text for TEAMNAME and SCORE.     Page 1: Additional rectangle (RED_BOX) appears on the left side of TEAMNAME. RED_BOX is set to be Hidden on Title TransitionIn as it need to be visible only when Page1 is set. Everything is working fine, TEAMNAME and SCORE might be changed and Title is keeping proper paging, but in case DataChange animation is added (f.e. for the SCORE data change) - =======  Animation is played and  hidden RED_BOX from page 1 also appears, while it is not supposed.======= If to check VMIX.API - Title SelectedIndex = 0. The situation is more dramatic if there are many Pages with objects which are going to be hidden by some rules.   After DataChange Animation runs -  all title objects are shown while SelectedIndex = 0 and Page 1,2,3,etc objects were set to be hiddenIn case if Page 3 was set and DataChange animation applied. VMIX.API is showing SelectedIndex = 3, while all pages' objects are visible. For me it sounds as a bug, then  after DataChange animation current Page setup is ignored.
	GT
