Hardware Compatibility
Behringer UMC404HD only mono Output
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
Good Morning!
I'm using a Behringer UMC404HD with the latest drivers on a Windows 11 Machine. I have 3 Audio Inputs via the ASIO-Driver which is working flawless. If I listen to the Stream on the Master, the Audio is great. If I want to map the Audio-Inputs to a Bus (f.e. Bus A is on the Behringer Output 1) I only get to hear everything on the left ear.
I first thought this might be because of a missing setting in vMix and tried the Audio Matrix but with no luck. Is there anything I'm missing? Or is there just no option to send Audio via just on output in Stereo?
