mat946
#1 Posted : Monday, October 31, 2022 7:23:54 PM(UTC)
mat946
Poland
Hi Guys,
I'm very new to vmix so please be kind, maybe my questions are stupid, but anyway I need an answer.
I need to produce a live stream, it is going to be vmix call kind of call.
1 Moderator and a few presenters, everything is supposed to be streamed in one language Polish.
1 of the speakers will be presenting in English and I need to provide simultaneous translation for it.
I think the best solution is to have a translator with the microphone right next to me, the safest option my opinion.
But the client keeps asking if it's possible to have a translator on vmix call also and translate it live remotely.
Do you think it is possible? How to provide and produce that kind of translation remotely?
Thank you for your help ;)
mjgraves
#2 Posted : Thursday, November 3, 2022 1:33:50 AM(UTC)
mjgraves
Short answer = Yes.
Longer answer, it can be a bit complicated. The company I work for (ZipDX) pioneered simultaneous interpretation (SI) over-the-phone about a dozen years ago, at the request of the UN.
Conversational SI allows for a meeting (vs one-way presentation) where everyone can be fully engaged. It allows taking questions from the floor in any language. What follows is a description of how conversational SI works.
You need a professional simultaneous interpreter who works in EN/PL.
There are several audio channels; Floor, English, Polish.
Participants who are bilingual listen to the floor.
EN speakers listen to the EN channel.
PL speakers listen to the PL channel.
Interpreters always listen to the floor.
When the interpreter hears EN they press a button to direct their speech to the PL channel and interpret into PL.
When they hear PL they direct their speech into the EN channel and interpret into EN.
The voice of the original speaker on the floor should be mixed under the voice of the interpreter. This is important to give the audience a sense that the interpreter is tracking the speaker well.
At ZipDX, our system is all VoIP. It can be/has been used with video conference systems. It's not free, or even cheap. Also, professional interpreters can be costly.
mavik
#3 Posted : Wednesday, November 9, 2022 4:30:36 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Thanks mjgraves. That is how one should do it professionally. But in this setup you can get away with a vmixcalled in interpreter. It's only EN -> PL and just for a single speaker. Make use of the busses available in vmix.
Master PL
Bus A EN/Talkback
So send bus A to interpreter call and voice to master
mjgraves
#4 Posted : Thursday, November 10, 2022 1:42:33 AM(UTC)
mjgraves
Yes, if it's a one-way flow (not conversational) it can be simpler.
mat946
#5 Posted : Wednesday, November 16, 2022 8:09:28 PM(UTC)
mat946
Poland
Thank you Guys, for your expertise ;)
It is a simple setup as you mentioned and I'm planning to have a translator next to me in the other room so it seems even easier.
Anyway, I will test it before the transmission.
Again, I'm sorry for the stupid question, but as I mentioned I'm a beginner with vMix.
aminal
#6 Posted : Friday, March 14, 2025 10:47:55 PM(UTC)
aminal
United Arab Emirates
Originally Posted by: mjgraves Go to Quoted Post
Short answer = Yes.
hats off , very deep answer
Guest (4)
