KDNWK
#1 Posted : Wednesday, October 26, 2022 7:48:39 AM(UTC)
KDNWK
Germany
Is there a way to prevent the fullscreen outputs from dimming?
For example when I hover over an application in the taskbar that has multiple or minimised windows, windows will show a preview an dimm all screens meanwhile. This also affects the Fullscreen outputs and can be inconvenient;)
Happened to be shorty when I used the Datasources window.
Is it clear what I mean? Otherwise I will try to add a video.
paco3346
#2 Posted : Wednesday, October 26, 2022 8:00:30 AM(UTC)
paco3346
This is a Windows feature known as peek.
You can disable it:
https://www.microcenter....sable-peek-in-windows-10
thanks 1 user thanked paco3346 for this useful post.
KDNWK on 10/26/2022(UTC)
