AUDIO PITCH CHANGES AFTER MINIMIZING VMIX AND USING OTHER APPLICATION
VMIX RUN PROPERLY TILL WINDOW IS OPEN IF I MINIMISE OR SEARCH FOR OTHER VIDEO SOURCE,AUDIO OF THE LIVE EVENT CHANGES AND PITCH GOES DOWN AND WHEN I RETURN TO VMIX AGAIN IT TAKES 5/7 SEC TO AGAIN MATCH THE ORIGINAL AUDIO
PLEASE HELP ME IF ANYONE HAVE SOLUTION FOR THIS OR ANYONE HAVE FACED THE SAME PROBLEM
I'm facing same problem .. did you find any solution pls help me !!
@ nepalikotv
This appears to be a limitation or power saving issue in Windows on some systems when active applications like vMix are minimized or running in the background, insufficient resources are allocated to the application to process audio causing it to change the pitch and/or speed of the audio playback. As such, you should never minimize vMix or run it in the background to avoid this Windows limitation.
