Move inputs to another preset.
Joined: 8/18/2013(UTC) Posts: 44 Location: Switzerland
Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
We have inputs with datasources which we would like to copy into a preset in another PC.
How can this be done?
It takes a lot of time to set the datasource in the preset of the PC.
Thank you.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Have you tried the "Save as Bundle". That will take all assets and you just need to copy the over to other computers.
Originally Posted by: mavik  Have you tried the "Save as Bundle". That will take all assets and you just need to copy the over to other computers. I just need a single input to insert to the existing preset of the other computer.
I tried to use the append for a single input with datasource. It adds the input but not the datasource. Only if I open the entire preset the datasource is added as well.
