aleclerc
#1 Posted : Tuesday, October 18, 2022 11:11:45 AM(UTC)
aleclerc
Canada
I try to add a local screen capture of a fullscreen Google Slide presentation.
- My monitor is 1920 x 1200
- Program is 1080p.
All I want to crop the 1200 to 1080 to get a clean capture without Google Slide's top and bottom black bars, and without vMix adding left and right transparent zone.
Unfortunately, the "Position" panel does crop on the final 1080p resolution. The cropping must be done before, on the original 1200 resolution. I just do not know how to do that. Or to simply ask the capture not to resize to 1080.
Is there any solution?
In OBS I simply had to center the screen capture on a 1080 canvas and it did the job.
Thank you for your help and kind regards.
