Hardware Compatibility
Action camera connected but no video
Joined: 1/19/2019(UTC) Posts: 4  Location: Bassano del Grappa Thanks: 2 times
Hi to all I'm having hard times connecting an usb action camera (apeman A79) to vMix. I would connect it like a webcam via usb. windows see it, I have video feed in the windows app, I can add it into vMix like any other camera, but it gives me black feed. I have a BMD Decklink duo2 with 3 inputs and 1 output working perfectly fine.
Can anyone please have an idea of what I'm doing wrong?
Thanx to anyone will help me out.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Svdiesel
It may be using a compression format that is not supported by vMix. Does it have an HDMI out? Or does it otherwise work in OBS via USB? (if so, it might be a viable workaround)
Indeed it has a (micro) HDMI out, I could add a capture device and do it that way. I didn't tried obs, There is already a lot of stuff going on on that PC... The thing is I don't really need that camera, It's a surplus and it coud be useful as beauty cam, but only if it's a simple hookup-and-go job... I was wondering why, if I can see it in windows and vMix allows me to add it, i can get an image out of it... I did think about codecs myself indeed, I surfed a little bit, but I could find nothing...
