ben1000
#1 Posted : Friday, September 23, 2022 3:40:35 AM(UTC)
ben1000
Howdy...
Has anyone played around with the advanced setting 'PREVIEW SKIP' for use on laptops as you start getting close to your resource limit?
I know the advanced settings are not supposed to be changed 'unless told by vMix support' (according to the manual), but I'd be happy to have my previews at 15 or 10fps if that significantly reduced the rendering time and cpu load...
Anyone played around with that before I dive in? Thanks!
Best,
Ben
