Virtual Camera options and Vmix errors
Hi. Sometimes I add some camera inputs to have different shooting angles and I mix them with virtual cameras created by third party software. The main problem I usually face is to figuring out the capabilities of the camera (FPS, resolution and video format). Even calling a ffmpeg dshow to show all the different configs the camera can handle, most of them give an error in vmix. For example, there's a virtual camera I'm trying to use created by the avatar system VSeeFace. The virtual camera (working on OBS), specifies a custom Resolution/FPS, 1280x720 and ARGB. All the modes this virtual camera handles are: pixel_format=bgr24 min s=1280x720 fps=30 max s=1280x720 fps=120 [dshow @ 000001d21064c280] pixel_format=bgr24 min s=1280x720 fps=30 max s=1280x720 fps=120 [dshow @ 000001d21064c280] pixel_format=bgr0 min s=1280x720 fps=30 max s=1280x720 fps=120 [dshow @ 000001d21064c280] pixel_format=bgr0 min s=1280x720 fps=30 max s=1280x720 fps=120 But any combination in Vmix gives the "Output" error. There must be a way to enumerate all the different properties of a camera compatible with Vmix (if any) This is a valid config for Twitch or OBS:  Thanks!!!
