Autostreaming to YouTube fails, manual streaming to YouTube works
I have a windows 11 computer set to reboot and begin autostreaming to youtube every morning at around 2:00 AM. The computer reboots, logs in the user, opens up vmix, and starts streaming. From my end, everything is working and the logs don't show any issues. But while youtube shows a connection, it isn't receiving any data from my stream. But if I stop the stream and press the stream key manually, everything works as intended.
In short: I can stream to youtube if I push the stream button myself, but not if I load the file via a .bat and call the api to autostream. Everything appears to be working on my side, but youtube doesn't receive any data. I have the exact same setup working on a windows 10 computer with no problems whatsoever.
Any suggestions for troubleshooting and/or fixing the problem?
