kirik
#1 Posted : Tuesday, September 13, 2022 10:10:31 PM(UTC)
kirik
Russian Federation
I propose to add the possibility of color correction using LUT files to each input (and to the master output).
This method, in contrast to the standard color correction, allows you to make custom color solutions and achieve a "delicious" image of streams.
I understand that most often LUT is used in a staged video. But sometimes LUT helps out a lot in live broadcasts, for example, concerts.
Now I personally use a workaround by running the master output from vMix to OBS, which has a LUT function
example1
example2
example3
#2 Posted : Wednesday, September 14, 2022 3:03:17 AM(UTC)
Check out
