EduardoSL
#1 Posted : Friday, September 9, 2022 2:02:41 PM(UTC)
EduardoSL
Brazil
I would like to ask for your help for a broadcast function.
My team tracks sporting events that we don't have the rights to broadcast, but this solution from this Brazilian YouTube channel seemed like a good idea: https://www.youtube.com/watch?v=WABTpLtQR5Y&t=3642s
They display the screenshot of the original broadcast every X seconds while the hosts present the information in real time.
I thought of doing the printscreen manually and saving to a folder, importing through 'Photos' and displaying as a slide in Vmix, but the import of new photos is not done automatically.
Another possibility would be to open the original broadcast on Vmix through Web Brower and display only the paused image, but I don't know if it would work as well, to recover the real time at each stop.
Does anyone know what the best solution is for this case?
Thank you
#2 Posted : Friday, September 9, 2022 4:17:06 PM(UTC)
Scripting would be an answer for you.
It helps to read through the various documentations and videos vMix offers though:
Like this for example and change for image (screenshot) plus add actions with the functions available to get it to where you want it to.
More scripting bits/ideas to add to your intended goal can be found here
The best way will be the one that works best for your , only way to find out is to try your ideas :-)
