RickBrock
#1 Posted : Friday, September 9, 2022 4:15:24 AM(UTC)
RickBrock
Hi all, here's something odd....
In v24.0.0.72 when I am recording it records audio.
If I press the little i next to the record button I see my audio device is "vMix Audio (D:0 M:0 S:0)
I updated to v25 and found that audio did not record. No matter how I set my busses, outputs or devices.
The little i next to the record button reported my audio device as "Line in (elgato audio capture)
I could not find a way to change that.
So I'm back to v24.0.0.72
My question....
Where is the setting for that Audio device?
Please and thank you
Rick
RickBrock
#2 Posted : Friday, September 9, 2022 4:18:42 AM(UTC)
RickBrock
Found it!
Go into settings and use the advanced option.
On the audio tab you get new options
Hooray
