Feature Requests
Possibility to rename an audio VST plugin to differentiate task
Joined: 3/7/2022(UTC) Posts: 72  Location: Munich Was thanked: 33 time(s) in 17 post(s)
Some audio VST plugins (e.g. BlueCat's Dynamics) can perform different tasks (e.g. Expander or Compressor). As the different tasks sometimes should be split (e.g. Expander applies earlier in processing chain and with different attack/release than the Compressor), those VST plugins on the SAME audio input are loaded multiple times. Unfortunately, vMix shows the plugins just by their name and does not allow this name to be edited. As a consequence you sees the name multiple times and you have to remember which instance played which role and hence performs which task. I would like to have the possibility to edit the audio VST plugin name to rename one "BlueCat Dynamics" to e.g. "Expander (BC-D)" and the other to "Compressor (BC-D)".
Feature Requests
