Feature Requests
Allow more file extensions when importing VB.Net scripts
Joined: 3/7/2022(UTC) Posts: 72  Location: Munich Was thanked: 33 time(s) in 17 post(s)
When importing VB.Net scripts under Settings / Scripts / Edit / Import the file dialog opens and expects files of the extension ".txt" ONLY, although the usual extension of VB.Net scripts is ".vb". This means that for every script import one first has to copy the file from "foo.vb" to "foo.txt" to be able to import it. Please support at least also ".vb", make it even the default for the dialog and additionally perhaps also allow arbitrary extensions to be selected, too. It really makes no sense to be such restrictive in this file dialog.
Feature Requests
