RTSP audio codec workaround?
Joined: 10/25/2014(UTC) Posts: 1 Location: London, UK
We were going to use your vMix software for a live event next week, and we have a bunch of Foscam IP Cameras, they provide a RTSP feed with the video using the H.264 codec, which works fine, but it doesn’t use the AAC codec for audio, so we’re not getting any audio from the camera feeds on vMix
Is there any way to add a plugin use ffmpeg or modify the software in any way so it would accept other audio codecs? Or any other kind of workaround?
Thank you for your help.
