Hello guys, I need to be able to modify by software the position in X, Y of a layer of the multiview of an input. Currently, via the SetPanX and SetPanY functions, I can modify the position of the "main" of the input. But I can't find a way to move one of its layers "1,2..." . Can you please help me? :)
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Sora592  Hello guys, I need to be able to modify by software the position in X, Y of a layer of the multiview of an input. Currently, via the SetPanX and SetPanY functions, I can modify the position of the "main" of the input. But I can't find a way to move one of its layers "1,2..." . Can you please help me? :) If one doesn't want to change the "main" of the input one can use a Virtual input of it to modify and use in the multiview. Virtual PTZ's is also an option (to quickly change "presets" )
Thank you for your answer However, I cannot use a virtual input because I need to change the input of the layers keeping the same X,Y position. I had already thought about this virtual input but it can't work in my case
