rnhturner
#1 Posted : Monday, August 22, 2022 2:05:13 AM(UTC)
rnhturner
Often when I have to use a camera to film something far off and at an angle I have to use the rotate feature in positions. The problem is that when I rotate it, if I crop it, it uses the same original angle. I want to be able to change the crop angle after a rotation.
I can hack it but it I am sure it is causing undue strain on my system as I have to output the rotated input to NDI out, then bring it back in just to crop it straight across.
