tanowalla
#1 Posted : Sunday, August 21, 2022 3:11:57 PM(UTC)
tanowalla
Argentina
I am adding a website with transparency using the the add Web Browser Source but the background stays white. I have tried adding it as a layer to check the transparency but it takes it as a white background. In OBS I can import the website with transparency with no issues. Also, in vMix i see the scroll bars, both bottom and right side. vMix 2.png (55kb) downloaded 2 time(s). vMix 1.png (242kb) downloaded 3 time(s).
My workflow right know is:
1. Add website to OBS
2. Put a Chroma Key colour under the layer.
3. Output Full Screen
4. Capture Screen in vMix
5. Chroma Key the green color so i can have the website transparency.
Why is this happening?
RichDanby
#2 Posted : Thursday, August 25, 2022 9:21:43 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
OBS injects the following CSS into pages to make default backgrounds transparent.
Code:
body { background-color: rgba(0, 0, 0, 0); margin: 0px auto; overflow: hidden; }
This is what I have in CSS on web overlays and vMix shows them as transparent with no scrollbars.
Code:
html {
	margin:0;
	padding:0;
	overflow: hidden;
body {
	margin:0;
	padding:0;
	overflow: hidden;
