roverradio
#1 Posted : Sunday, August 21, 2022 9:43:01 AM(UTC)
roverradio
I have a use-case where I'd like to change the directory where recordings are made. From what I can gather, it's impossible to set either the recording directory or the recording filename formatting via API, correct?
Just wanted to be sure before I contemplate alternate ways of doing what I want.
Thanks!
vmixgreg
#2 Posted : Sunday, August 21, 2022 9:47:06 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Correct
