reezyfasheezy
#1 Posted : Friday, August 12, 2022 5:43:42 AM(UTC)
reezyfasheezy
I am having an issue with the Virtual audio cable in vMix. I have 2 audio sources, my mic and a music playlist. I am sending the external video output going into zoom, with bus b going to the virtual audio cable. My microphone works fine going through the VAC, but the playlist will work sometimes, but then not. It’s been impossible to test as my mic will go through fine, when I send a test signal through the VAC itself, it works fine, but when I play my playlist- sometimes it works, and sometimes it doesn’t. I’ve tried restarting vMix, re-adding my playlist, un assigning and then re-assigning the bus within vMix, but nothing works. The audio just goes through when it wants. Any ideas? I have yet to uninstall and then reinstall the VAC, but that is next on my list.
