Feature Requests
repeated request: separate overlay options for rec and stream
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
Hi Martin,
I can now select which overlay to choose for full screen and Recording/Streaming.
But frequently I want to stream with different overlays than the ones I (don't) want to record.
Could there be a separate set of overlays to choose for external AND recording. So p.e. I can display a ticker with overlay 3 in the lifestream but not record it.
Why is there a separation for fullscreen and rec/stream anyway? Would it be simple if it would be fullscreen/stream and rec separated in the overlay options lists. Maybe a quick fix this.
Stefan
Feature Requests
