foxy
#1 Posted : Friday, July 29, 2022 6:42:56 PM(UTC)
foxy
It seems the UI has a small bug in that whilst it is possible to assign a dynamic input to a shortcut for a midi controller change to adjust a dynamic input, the same option is not possible for activators - purely because the dropdown list doesn't include the 4 dynamic inputs.
i appreciate that it would possibly need extra logic because the inputs are dynamic - however the methodology for handling dynamically changing inputs is already supported, as both "preview" and "active" inputs that appear on the existing list are by definition dynamic.
i suspect that it's just an oversight and the 4 dynamic input values could be added to this list in a future release?
