adambou
#1 Posted : Tuesday, July 26, 2022 8:58:13 PM(UTC)
adambou
Sports stream. Main build is camera with scoreboard title loaded and then added via multi view.
When I add an instant replay - somehow the scoreboard is displayed in the bottom of the replay screen as if I had built it in with a multi view but multi view is not in use at all on the replay.
I have no idea how this is happening or how to correct it. I want nothing overlaid on the replay at all. I’ve set this up many times before and never had this problem before. If anyone can help I will be most grateful.
#2 Posted : Tuesday, July 26, 2022 9:44:31 PM(UTC)
@ adambou
The only way that would happen is if you are capturing a vMix Output as a camera source.
