	Feature Requests
	Audio Input Settings: Possibility to open ASIO Control Panel of driver
 Joined: 3/7/2022(UTC) Posts: 72  Location: Munich Was thanked: 33 time(s) in 17 post(s)
                When using ASIO inputs, there is no possibility to open the corresponding ASIO Control Panel of the underlying driver. In nearly all DAWs and similar audio applications which support ASIO, there is always a button to open the control panel. This is especially important if necessary configuration have to be applied there. An example is this: vMix should use BlueCat's Connector ASIO driver for ingesting remote audio streams. As the ASIO driver's control panel cannot be opened from within vMix, it is hard to configure BlueCat's Connector (its TCP ports). A workaround is to use the free utility "asioconfig.exe" to open the control panel, but this is just a nasty workaround. Please add a button to raise the ASIO Control Panel of the underlying drivers. Thanks!
	Feature Requests
