fat cat
#1 Posted : Wednesday, July 13, 2022 10:40:27 AM(UTC)
fat cat
Canada
I tried to use Excel spreadsheet as the data source but VMIX cannot show the pictures that are in the Excel spreadsheet.
I first used Adobe AI and edited all the pictures with the same size and saved as PNG files, then I insert them in the Excel spreadsheet. Then I used VMIX to retrive the data from the Excel spreadsheet, ending up it could only retrived some of the PNG pics, so not all pictures showed. If someone can help me with this that would be great.
Thank you so much!
dmwkr
#2 Posted : Wednesday, July 13, 2022 3:28:55 PM(UTC)
dmwkr
Don't insert the pictures into the spreadsheet as pictures, write the file paths (as text) into the cells.
https://www.vmix.com/help25/DataSourcesImages.html
fat cat
#3 Posted : Wednesday, July 13, 2022 4:11:37 PM(UTC)
fat cat
Canada
i did.
thank you for your replay
