Trchanner
#1 Posted : Friday, July 1, 2022 10:06:25 PM(UTC)
Trchanner
Hi I am new to using VMix software. I am testing streaming to YouTube. Audio volume is low and streaming is delayed. Any advise?
Speegs
#2 Posted : Saturday, July 2, 2022 10:28:00 AM(UTC)
Speegs
Generic advice, make sure you have all the latest drivers. Maybe uninstall, reinstall, reboot. I use other audio capture devices and usually find drivers can give problems. Often after a windows update, then going back to the makers website and getting the latest often corrects it.
thanks 1 user thanked Speegs for this useful post.
Trchanner on 7/2/2022(UTC)
mtone
#3 Posted : Saturday, July 2, 2022 1:50:32 PM(UTC)
mtone
check the x32 routing where you are tapping the signal being sent to "CARD".. this is the usb audio source, if the signal is being sent post fader this would affect levels.
thanks 1 user thanked mtone for this useful post.
