Philip Greenwood
#1 Posted : Thursday, June 23, 2022 3:46:57 AM(UTC)
Philip Greenwood
I have a problem if a USB comes loose or if I unplug a USB if Vmix is running, Vmix just freeze which need to be closed using task manager. This is on Windows 10.
Any ideas
#2 Posted : Friday, June 24, 2022 5:43:12 PM(UTC)
While it might be something for vMix to look into to prevent the program from freezing first step would be to make sure the USB connections are solid.
Programs freezing is not an uncommon thing when USB deices get unplugged (hence the option to click to safely unplug a usb device)
My wires are loose in the switch so the light goes out sometimes , helps to tighten the wire connections ;-)
