Joined: 11/6/2020(UTC) Posts: 21 ![Russian Federation Russian Federation](/Content/images/flags/RU.png) Location: Saint-Petersburg Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
This script is for smooth movement of the graphics like Merge does Code:'start point
dim P0 as double = 0
'end point
dim P1 as double = 7
dim B as double = 0
dim t as double = 100
for i as double = 0 to 100
B = (((1-(t/100))^3)*P0 + 3*t*((1-(t/100))^2)*P0 + 3*((t/100)^2)*(1-(t/100))*P1 + ((t/100)^3)*P1)/10
dim Bs as string = B.ToString
If Bs.Contains(",") Then
Bs = Bs.Replace(",", ".")
End If
API.Function("SetPanX", Input:="title.png", SelectedIndex:="0", Value:=Bs)
t=t-1
sleep(20)
next
