Joined: 3/12/2020(UTC) Posts: 6 Location: Hanoi Thanks: 3 times
Hi, I have a problem with the source dropped when I start recorded instant replay 3 input 4k60 ( Source Dropped ) My PC Specs: Mobo: GIGABYTE B550 VISION CPU: Ryzen 5950x GPU: RTX 3080ti RAM: 64GB SSD: Samsung 980 1tb Capture: Decklink 8k Pro So, I'm looking for a System Specification for Vmix Instant Replay with 4-5 input 4k60 + 1 external 4k60. I confuse between Intel Xeon & Threadripper. If anyone has suggestion, please tell me. Thanks.
Joined: 8/20/2021(UTC) Posts: 16 Location: Cologne Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
As for now, vMix by default is not able to use more than 2 cameras for 4k60 replay. So better stick to FullHD along your signal chain for 4-5 cameras in instant replay.
Also, Ryzen isn't really the best choice here in terms of pcie lanes and memory channels. You'd be better with Intel X299 and X-series Intel-Core processors. They have more pcie lanes and also more memory channels. If you have an 30-series NVIDIA graphics-card (16 pci lanes) and 2x Decklink 8k Pro (2x 8 lanes) you are already well above the total pci-lane count of your ryzen. So the bottleneck really would be your mobo only using a reduced amount of pcie-lanes for each card or managing all the data, prioritizing and communicating in serial. Both would be more or less suboptimal for real-time use.
GPU and RAM are well above what you need, vMix recommends a GTX 1080 ti or higher and at least 16GB DDR4 for 8 channel HD- or 2 channel 4k replay.
In addition, temperature could also be a problem, since the Decklink cards only have a maximum operating temperature of 50 °C. If you have a 3080 ti next to them blasting hot air close, that maximum temperature will be reached easily. A blower-style graphics-card would be a better in this case.
I hope I could provide some helpful information for you Jan
2 users thanked Jaa_Han for this useful post.
