trufflepig
#1 Posted : Wednesday, May 25, 2022 9:58:44 AM(UTC)
trufflepig
Canada
I used vMix in combination with Companion+Streamdeck XL as my hardware switcher. I use list inputs with lower third .png's loaded into them with the string "$(vmix:input_1_name)".
I used to be able to leave the input name blank so that my Streamdeck would show the current filename on the button. With the newest update, you cannot leave a List input blank so it always appears as 'List' on my Streamdeck instead of the filename. No other input types have this behaviour. Example below - you can see the Image input beside List is using the filename since I left the input name blank within vMix:
Streamdeck
Is this something that can be rectified in a new vMix update or does anyone know a way around this within Companion?
Thanks in advance!
