Bikeroo
#1 Posted : Saturday, May 21, 2022 12:37:51 AM(UTC)
Bikeroo
Poland
Unfortunately I had a recording that was interrupted by a blue screen crash.
After that I see the recording files (mp4). They have few gigabites, so there are some data inside.
But I can't open it.
I have try to import them to Premiere Pro but it says that files are not supported.
Do you have idea, is there any possibility to recover these files?
melody
#2 Posted : Saturday, May 21, 2022 1:31:43 AM(UTC)
Rank: Guest
Groups:
hi... don't worry, it happened to me before...
there is a software called MP4 Video Repair Tool, link bellow
https://codecpack.co/dow...4-Video-Repair-Tool.html
it works very well, good luck
cheers,
melody
Bikeroo
#3 Posted : Saturday, May 21, 2022 3:43:44 AM(UTC)
Bikeroo
Poland
Oh that was awesome solution, thank you!
It works!
I got video with great quality from this software.
Unfortunately It not extracting the audio, only video.
But audio channel I have extracted from this tool:
https://restore.media/
But anyway thank you so much! :-)
