I have this idea to create a playlist of 5 camera's, who are looping all day for 15 seconds. But I would like to add music underneath it. As in: a separate audio file(s). Is that possible? :
It is possible to do this. Add your music in a list,enable audio button,disable auto mix audio so it will play always and then do the playlist for your cameras
This is brilliant! Thank you very much!
I have been doing this for years now....What I do, I load all the audio files as a 'list', place them in the order I want them to play, and click on "auto next" and "loop", and play them from the input window, while I have my "Video List" playing out, or cameras switching....I do this when I have functions to stream, or show in closed circuit, so that persons will not just have a blank screen to look at...
